door rollers for companion way door - Printable Version +- Tiara Yacht Owners Forum (https://www.tiaraownersclub.com/forum) +-- Forum: Tiara Yachts Discussion Forum (https://www.tiaraownersclub.com/forum/forumdisplay.php?fid=6) +--- Forum: General Repairs & Maintenance (https://www.tiaraownersclub.com/forum/forumdisplay.php?fid=10) +--- Thread: door rollers for companion way door (/showthread.php?tid=1193) |
door rollers for companion way door - kurts52 - 02-17-2015 Does anyone know of a source for the roller assemblies for a 1997 Open companion way door. Need top and bottom. Tiara doesn't use that system any longer and have none for replacement parts. Thanks Kurt RE: door rollers for companion way door - Harwood - 02-18-2015 (02-17-2015, 05:25 PM)kurts52 Wrote: Does anyone know of a source for the roller assemblies for a 1997 Open companion way door. Need top and bottom. Tiara doesn't use that system any longer and have none for replacement parts. Looking for the same here for a 97 3100 Open. If you find them, would be interested to know where. I'll do the same on my end. Thanks- Kurt, I bookmarked this site last year - I now see from your prior post that you have already disassembled your door. Does anything here look right? Here's the link in case you have not found these guys before: http://www.fpmarine.com/Door-Track-s/783.htm RE: door rollers for companion way door - kurts52 - 02-18-2015 No sorry that is the train and truck system that is used now. What I am doing is I have taken the roller assy apart now from the door and bought new roller bearing according to the pin size hole. They are smaller outside diameter but much better bearings. I am having new ones made out of nylon with the new bearings pressed fit into them. I was trying to figure out a way to adapt the truck and train system to the door but it was to complicated. Let me know if you come up with anything RE: door rollers for companion way door - Harwood - 02-20-2015 Thanks for the info, Kurt. If I read your post correctly, you've already determined that the 1997 yr used the old style (as I suspected) and that adapting the new style system is a PIA... I guess I'll keeping looking, then! RE: door rollers for companion way door - kurts52 - 02-20-2015 (02-20-2015, 10:03 AM)Harwood Wrote: Thanks for the info, Kurt. If I read your post correctly, you've already determined that the 1997 yr used the old style (as I suspected) and that adapting the new style system is a PIA... Correct. It would require cutting off the top and bottom of the door, maybe even the glass to use the current system. going to still work on a solution though. Actually taking the bearings to a guy today to have the new ones made. RE: door rollers for companion way door - Chris Burkard - 02-23-2015 Tiara did not manufacture that truck and track system. Someone out there has to either still manufacture those, or if not, someone has to have some new/old stock to replace those. Where you able to get a manufacture off the door parts? RE: door rollers for companion way door - kurts52 - 02-23-2015 (02-23-2015, 02:15 PM)Chris Burkard Wrote: Tiara did not manufacture that truck and track system. Someone out there has to either still manufacture those, or if not, someone has to have some new/old stock to replace those. Where you able to get a manufacture off the door parts? Chris Have not been able to locate a source for the rollers. meeting with a buddy of mine right now and he is going to make them Thanks Kurt RE: door rollers for companion way door - erikfrasco - 05-26-2022 (02-18-2015, 11:01 AM)kurts52 Wrote: No sorry that is the train and truck system that is used now. What I am doing is I have taken the roller assy apart now from the door and bought new roller bearing according to the pin size hole. They are smaller outside diameter but much better bearings. I am having new ones made out of nylon with the new bearings pressed fit into them. I was trying to figure out a way to adapt the truck and train system to the door but it was to complicated. Let me know if you come up with anything I Have a 96 3300 Door sticks on closing it at the 3/4 mark How did you get yours working?? Erik Frasco |
