Radar install - Printable Version +- Tiara Yacht Owners Forum (https://www.tiaraownersclub.com/forum) +-- Forum: Tiara Yachts Discussion Forum (https://www.tiaraownersclub.com/forum/forum-6.html) +--- Forum: Electronics & Navigation (https://www.tiaraownersclub.com/forum/forum-28.html) +--- Thread: Radar install (/thread-1603.html) |
Radar install - johnnyp - 05-31-2015 I own a 29 tiara with a hard top, and I'm installing a radar. The cable for the radar dome comes with connectors already installed. Which makes it very difficult to fish the cable through tubing of the hard top supports. Has anyone have or had this problem? And can the cable be cut and spliced, which would make the install much easierl. RE: Radar install - Uhehner - 05-31-2015 DO NOT CUT the cable!!!!!!!! DO NOT CUT the cable!!!!!!!! DO NOT CUT the cable!!!!!!!! I'll bet the cable can be disconnected from the terminal board in the dome, wrapped with tape and pulled up the pipe from the bottom. I did not say it was easy but cutting and splicing is major surgery. Capt. George RE: Radar install - johnnyp - 06-01-2015 Thanks Cap. George, The cable has several connectors on the dome end. I'll try to remove the connector pins from the connector and tape up all the wires. And your 100 percent correct, it's not going to be easy. I just hope I don't break off any of the connector pins from the wires. (05-31-2015, 03:49 PM)Uhehner Wrote: DO NOT CUT the cable!!!!!!!! DO NOT CUT the cable!!!!!!!! DO NOT CUT the cable!!!!!!!! |
