Fresh Water Tank Removal - Printable Version +- Tiara Yacht Owners Forum (https://www.tiaraownersclub.com/forum) +-- Forum: Tiara Yachts Discussion Forum (https://www.tiaraownersclub.com/forum/forumdisplay.php?fid=6) +--- Forum: AC/Heat, Plumbing & Sanitation (https://www.tiaraownersclub.com/forum/forumdisplay.php?fid=29) +--- Thread: Fresh Water Tank Removal (/showthread.php?tid=1639) |
Fresh Water Tank Removal - TheCooperCrew - 06-07-2015 I have a 1990 Open with the aluminum fresh water tank that is leaking quiet a bit from the welds. Just curious if anyone has removed one and how? I am really not wanting to cut through the floor to remove it. RE: Fresh Water Tank Removal - tedemerick - 07-30-2015 I have the same problem. After much investigation I plumes the tank pump to the fresh water intake put a strainer and 3m .02 micron filter on and it works great. Can not drink the water but we never did. Cost about $300. Sent from my SM-N910V using Tapatalk RE: Fresh Water Tank Removal - TheCooperCrew - 09-08-2015 [quote='tedemerick' pid='4738' dateline='1438279529'] I have the same problem. After much investigation I plumes the tank pump to the fresh water intake put a strainer and 3m .02 micron filter on and it works great. Can not drink the water but we never did. Cost about $300. Sent from my SM-N910V using Tapatalk [But you still can't have water at sea, right? I get fresh water from the dock through the freshwater inlet without any pump because my freshwater hose inlet bypasses the tank. If I fill up the water tank thru the tank fill, the water leaks out of the corroded holes once the pump puts pressure to it. Tiara CS mentioned using a plasma cutter to cut the tank out and install a new one, or cut an opening in the tank and install a bladder as options. Guess I'm going to give it some more thought and work on it as my winter project ] |
