[Tiara Open] Capt Brett from MD - Printable Version +- Tiara Yacht Owners Forum (https://www.tiaraownersclub.com/forum) +-- Forum: Tiara Yachts Discussion Forum (https://www.tiaraownersclub.com/forum/forumdisplay.php?fid=6) +--- Forum: AC/Heat, Plumbing & Sanitation (https://www.tiaraownersclub.com/forum/forumdisplay.php?fid=29) +--- Thread: [Tiara Open] Capt Brett from MD (/showthread.php?tid=4267) |
Capt Brett from MD - CaptBrett - 04-08-2017 I have a 01 38' Open, love the boat, and have been doing lots of updating.... I am now having a hot water heater issue. Not getting any hot water, any thoughts? Please advise Sent from my iPad using Tapatalk RE: Capt Brett from MD - Dakota773 - 04-09-2017 I'd bet that the heating element has gone bad. I had to change mine out late last year on my 98 31 Open. Simple part, tough to pull the water out a to get access to the element on the 31. Not sure on your 38'. If you have heat exchangers from the engine(s) and have hot water when running or thereafter, it'd have to be the element. If you have none either way, there must be some other cause. Capt Brett from MD - CaptBrett - 04-09-2017 (04-09-2017, 04:28 PM)Dakota773 Wrote: I'd bet that the heating element has gone bad. I had to change mine out late last year on my 98 31 Open. Simple part, tough to pull the water out a to get access to the element on the 31. Not sure on your 38'. Thank you sir.... its not getting power. Sent from my iPad using Tapatalk |
