TWO SENDING UNITS FAILED ! - Printable Version +- Tiara Yacht Owners Forum (https://www.tiaraownersclub.com/forum) +-- Forum: Tiara Yachts Discussion Forum (https://www.tiaraownersclub.com/forum/forumdisplay.php?fid=6) +--- Forum: Diesel Engines/Transmissions (https://www.tiaraownersclub.com/forum/forumdisplay.php?fid=27) +--- Thread: TWO SENDING UNITS FAILED ! (/showthread.php?tid=502) |
TWO SENDING UNITS FAILED ! - jcarrollgm - 09-01-2013 It seems that both my fresh water tank and my holding tank sending units have failed within weeks of each other. My boat is a 2006 Tiara 4200 Open. Is this a common fault on this model? Is it an easy fix to replace them or does it require a professional repair person? :help: TWO SENDING UNITS FAILED ! - BustAndBalls - 09-04-2013 Are both senders feeding a single panel? TWO SENDING UNITS FAILED ! - jimsea - 09-04-2013 I just bought a 2006 36' Sovran with same issue. TWO SENDING UNITS FAILED ! - anthem - 09-04-2013 Is it really the sending units? Or is it the rocker switch? I have a 38 open. The waste and water operate off the same rocker switch. When I toggle back and forth both tanks show 1/2. I know both tanks are empty. I don't think it's the senders.....I think it's the guage. TWO SENDING UNITS FAILED ! - jimsea - 09-05-2013 My Sovran has soft keys on the gauge, no rocker switch, waste tank shows full all the time (not a good feeling) water tank empty all the time TWO SENDING UNITS FAILED ! - Chris Burkard - 09-05-2013 The sending units on the waste tank are notorious for failing. The water tank sending units do fail every few years. Not uncommon. It could however be the gauge as mentioned above. Tiara eventually went to electrical sensors sometime in the mid to late 2000s as the mechanical float sensors were notorious for failing. Even the electrical sensors are not full proof and can and do fail, just not as often. If you are mechanically inclined, have tools and like hot cramped spaces, you can replace sending units. Keep in mind the black water tank sensor will not be pleasant to replace. Have a hose, gloves and large plastic bags ready at the reach when doing this. A full face mask respirator would also be a plus! If you don't have a face mask respirator, make sure you wear eye protection and gloves. A drop of raw sewage in the eyes or in a cut can spell disaster! Sorry to be graffic, but my dad ended up with a staff infection that put him in the hospital for several days after messing with the blackwater tank. Good luck! Good Luck! |
