Dometic A/C pull out. - Printable Version +- Tiara Yacht Owners Forum (https://www.tiaraownersclub.com/forum) +-- Forum: Tiara Yachts Discussion Forum (https://www.tiaraownersclub.com/forum/forum-6.html) +--- Forum: AC/Heat, Plumbing & Sanitation (https://www.tiaraownersclub.com/forum/forum-29.html) +--- Thread: Dometic A/C pull out. (/thread-8488.html) |
Dometic A/C pull out. - giff1 - 11-25-2022 I'm pulling out my Dometic Marine AIRRRR, Vector Compact. I have the water and drain hoses off and unbolted from the floor. The electric box access is giving me trouble. I can't find any set screws holding the cover on. It seems the cover just slides up and off but it is stuck. Anyone know how this cover comes off so I can disconnect the wires. RE: Dometic A/C pull out. - jclark003 - 11-25-2022 If I remember correctly the control box has a cover that slides up and over an open box that holds the control board. The last one I opened had a single screw in the top middle forward face. Remove that screw and the cover slides up and off. Wiring should enter from the bottom. I had to use a bit of force to get the cover off as it is a tight fit. |
