Tiara Yacht Owners Forum
LED - Printable Version
+-- Forum: Tiara Yachts Discussion Forum (https://www.tiaraownersclub.com/forum/forumdisplay.php?fid=6)
+--- Forum: The Tiara Yachts Project Center (https://www.tiaraownersclub.com/forum/forumdisplay.php?fid=11)
+--- Thread: LED (/showthread.php?tid=89)
LED - cjay - 09-16-2011
I bought a strip of LED lights and decided I could do it. It was very very simple. Total time < 2hours.
LED - Lured Away - 09-19-2011
Looks good I did the same with rope lights and the blue. Also added these I2 Aperion tri-color lights in the arch or hardtop.
LED - GCAT9110 - 02-11-2013
LEDs the future of marine practical and creative lighting. Gota-a-luv-m
LED - captainbroz - 04-28-2013
Can you tell me where did you buy led strip? Is it water proof?
Thanks in advance.
Mark
1988,36 open
LED - cjay - 04-30-2013
I bought them from Rob at xtremeled.com They are waterproof. They have been in for over a yer and are doing great. They look as good as the day I installed them.i used gorrilla glue to mounth them as the underside was not smooth enough for double stick tape.
LED - Uhehner - 04-30-2013
Go to eBay and search "SMD 5050 waterproof". About $40 from China with some extra 4 conductor wire. I cut 1" square, 3/8" PVC and drilled a 1/8" vertical hole. Then I used 5200 to glue the PVC in place and small ty-wraps to hold the LED strip after the 5200 set. I used the multicolor 5M string and it was the perfect length for my 36 convertible but you need to cut it in two lengths and meet at the walk thru door. Looks great especially when the colors change automatically. They operate on 12 volts so its an easy connection to the circuit breaker panel. Comes with an IR remote.
Capt. George
LED - Steed36 - 04-30-2013
Looks great - I am going to do the same -just ordered some online.
Hope you got my response on the ladder!
Steve
LED - cjay - 06-26-2014
FYI, I just replaced mine. After the years they seemed to dim and one side went out. They are cheap enough now, that I don't mind replacing every other year.
RE: LED - Freedomskeeper - 05-07-2015
[attachment=101][attachment=102][attachment=103]
The PO had some LEDs plugged into the 120v outlet when I bought the boat. I checked and sure enough they were 12v powered by a step down. I wired them in to the cabin lights circuit on the 12v system and now  we have 20+ colors to set the mood! More light and less draw. The next step is to re-wire the ones in the salon.
