Somehow I think I bent (warped) the steeling wheel, and I would like to have it straightened. I got the cap off, and then there is a nut, I got the nut off, but nothing. I cant tell if there is a retaining ring, or snap clip or not that needs removed. Someone suggested beating on the nut and it should pop lose. So Before I try that, I thought I would ask, and see if there is something simpler. TIA
(it is one of those pretty big (2'?) in diameter wheels with wood on the outside)
01-23-2017, 02:40 PM (This post was last modified: 01-23-2017, 02:43 PM by efontana.)
(01-23-2017, 02:18 PM)sluggo Wrote: [Only registered and activated users can see links Click here to register]
You put the center bolt (with the point) in the center of the bolt (that you removed the nut from), then adjust the grabbers around the stainless ring, then using a wrench turn the center bolt.
(01-23-2017, 02:40 PM)efontana Wrote: [Only registered and activated users can see links Click here to register]
(01-23-2017, 02:45 PM)sluggo Wrote: [Only registered and activated users can see links Click here to register]
(01-23-2017, 02:49 PM)efontana Wrote: [Only registered and activated users can see links Click here to register]
Thanks! so to be clear you have the same boat?? TIA
Yep!Thanks again! I'll stick it on there and try and not worry about the little thing I think is some sort of keyway.
(01-23-2017, 02:52 PM)sluggo Wrote: [Only registered and activated users can see links Click here to register]
The piece of metal, "the key" stays in the square groove in the shaft and wheel hub. I replaced my wheel with a new one, and the new wheel came with a new key. Make sure you don't drop and/or lose the key. It will come right out no problem with the puller.
