Has anyone had any success with replacement of the center window wiper motor ????
I have talked with Brian Kane at TIARA and he states i need the following:
Part # 334229 WIPER, MOTOR AFI-GM2 #37291 (95 DEG.)
Made my AFI . # 37291
can't seem to find this anywhere ????
Help?
Thanks,
Capt. Brett M. Sause
USCG Master Licensed Captain
443.220.4339 [Only registered and activated users can see links Click here to register]
My 36 had AFI wiper motors and I replaced them with Five Oceans Heavy Duty Wiper Motor found on Amazon. These seem to be a direct replacement for mine except for the wiring connection is a spade connection vs. a screw terminal. They have the home park option as well. Good luck.
Would you mind sharing the exact model that you purchased from Amazon and let me know if you had any issues with clearances or issues closing the center window and rubbing against the fiberglass? I had a similar problem to many others where the wiring corroded and would like to replace the entire motor, but only if the form factor of the replacement is the same or smaller than the original AFI model.
(08-28-2018, 07:55 AM)CaptGregSTX Wrote: Would you mind sharing the exact model that you purchased from Amazon and let me know if you had any issues with clearances or issues closing the center window and rubbing against the fiberglass? I had a similar problem to many others where the wiring corroded and would like to replace the entire motor, but only if the form factor of the replacement is the same or smaller than the original AFI model.
Thanks much!
Capt Greg
did you ever get your wiper fixed? and what did you do ?
Yes, I replaced the wiper motor with a smaller form factor one, with less overall range, but it works well and looks good. Found an AFI Marine Wiper Motor NEW Part # 37181 with an 80 degree range for less than $150 on eBay. The overall form factor was smaller and had to drill a hole for the set screw (and fill the old screw hole), but it works great and looks factory.
