Scupper Flange Replacement on 2006 3200
Just noticed a crack and missing piece in black external scupper flange on hull side. Looking for help on a couple questions.
Does anyone know a good source for this part ( I will also call Tiara tomorrow)? Can anyone help with replacement tips? Is this a cosmetic piece or does it require rebedding? Thanks for the help.
It is not cosmetic. You will need to replace the entire scupper, inside and out. I replaced mine two seasons ago. Not a terribly tough job. You will most likely need to break the old ones to get them out. I used APF Marine group. They were half the cost of Tiara and the parts and service were both great. They say you should replace them every 10-15 years or so anyway to make sure there is no moisture getting in.
Thanks for the reply. I did also talk with Tiara today and they said I was able to replace the flange alone and not disturb the rest of the assembly. They are shipping a part, but based on your comments It sounds like I may need more parts. I’ll be down there this weekend to try and disassemble and see what needs to be done. Thanks again for the response.
Yours is 4 years newer than mine so i guess that could be if they changed something. When I called them they told me the entire scupper needed to be changed.
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 420 08-18-2026, 02:11 PM
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 395 07-25-2026, 09:15 AM
Last Post: roboh20
  Freezer Replacement for 40' Tiara Reprise1 4 1,777 06-09-2026, 02:28 PM
Last Post: fuzzy
  Tiara Express Battery Charger Replacement Svdb12@chartermi.net 0 663 09-07-2025, 11:19 AM
  [Tiara Sovran] Shore Power Cable Replacement wwaseleski1953 2 1,315 06-12-2025, 07:50 AM
Scupper Flange Replacement on 2006 320000
