I own a 2004 Coronet 2900 with 5.7 Crusaders with 1900 hours. Both engines need elbows, exhaust manifolds, oil and transmission coolers. Oil analysis shows salt in Port engine so probably needs valve job. Probably will do both engines at the same time. Also considering re-power with Crusader 6.0 MPI non catalytic. Any comments and do I need differ props for reposer.
Author's Statistic:
Threads: 1
Likes Given: 14
Likes Received: 5 in 4 posts
Home Port: Newport Beach,CA
Vessel Info: I work for the Westcoast Tiara dealer Silver Seas Yachts. I'm one on the lucky few who gets to try all the models and engine combos.
Threads: 1
Likes Given: 14
How does Indmar engines compare with Crusaders. I know Crusaders are more expensive but how is the durability. How many hours should a gas marine engine last?
Author's Statistic:
Threads: 1
Likes Given: 14
Threads: 1
Likes Given: 14
I think they are pretty good. Did you look at the spec’s? It’s a turbo 4 cylinder making 310HP and very light compared to your 5.7L. Plus you would have tons of room to around them and good burn rates.
Author's Statistic:
Threads: 6
Likes Given: 1
Likes Received: 51 in 48 posts
Home Port: Kings Park, NY
Threads: 6
Likes Given: 1
Author's Statistic:
Threads: 1
Likes Given: 14
Threads: 1
Likes Given: 14
Author's Statistic:
Threads: 1
Likes Given: 14
Threads: 1
Likes Given: 14
(11-11-2019, 06:00 AM)ReelMagic Wrote: Noticed the Spec's call for 93 octane fuel. Around here there aren't many marinas carrying 93 octane. Do they run OK on 87???
From Indmar
“The power loss with 91 should be very minimal. Below is the fuel recommendation from the Owner's Manual. “
Larry Engelbert
Indmar Marine Engines
901-353-9930 Ext. 1050
Author's Statistic:
Threads: 1
Likes Given: 14
Threads: 1
Likes Given: 14
(11-10-2019, 11:38 PM)billholly Wrote: I own a 2004 Coronet 2900 with 5.7 Crusaders with 1900 hours. Both engines need elbows, exhaust manifolds, oil and transmission coolers. Oil analysis shows salt in Port engine so probably needs valve job. Probably will do both engines at the same time. Also considering re-power with Crusader 6.0 MPI non catalytic. Any comments and do I need differ props for reposer.
Have you checked compression and done a leak down check on your 5.7L?
