Author's Statistic:
Threads: 86
Likes Given: 0
Likes Received: 6 in 6 posts
Home Port: ludington michigan
Vessel Info: 2003 4200 open qsm 11 660hp
Author's Statistic
Threads: 86
Likes Given: 0
would like to install a more powerful raw water washdown on my boat, is that a big job? is it as simple as just changing the pump to a more powerful one? do i have to change any plumbing or fuses? mine is just too weak of stream for my liking, thanks in advance.
Author's Statistic:
Threads: 3
Likes Given: 165
Likes Received: 50 in 46 posts
Home Port: Ashtabula, OH
Author's Statistic
Threads: 3
Likes Given: 165
You will need to check the breaker and wire size to your current pump and make sure it will be sufficient for the new one.
I changed my nozzel and hose last year and it made a difference in mine. Not a huge improvement, but enough for me to keep my current setup for now.
Author's Statistic:
Threads: 12
Likes Given: 29
Likes Received: 17 in 17 posts
Home Port: South haven,mi
Vessel Info: 2006 3200 0pen 8.1 crusaders
Author's Statistic
Threads: 12
Likes Given: 29
I changed mine to 7 gpm it was a improvement but not what I was hoping for. I think the quick connects and the diameter of the hose are slowing the gpm out of the nozzle. Make sure your strainer is clean, In south Haven we had terrible duck weed last year and it will plug up anything. I know in ludington you are graced with really clean water but there will still be some in there.
Author's Statistic:
Threads: 86
Likes Given: 0
Author's Statistic
Threads: 86
Likes Given: 0
thank you guys......
Author's Statistic:
Threads: 20
Likes Given: 3
Likes Received: 3 in 3 posts
Home Port: Suffolk County, NY
Vessel Info: 2001 38 Open; Cummins 6CTA8.3 450HPx2
Author's Statistic
Threads: 20
Likes Given: 3
Look fir higher PSI pumps, not just GPH
Author's Statistic:
Threads: 13
Likes Given: 0
Likes Received: 0 in 0 posts
Home Port: Marblehead Ohio
Vessel Info: 1988 Tiara 3100 Open, twin Crusader 350 gas engines
Author's Statistic
Threads: 13
Likes Given: 0
(02-13-2021, 12:20 PM) OurHighLife Wrote: Look fir higher PSI pumps, not just GPH
Size matters, use the largest ID piping you can get and match up the ID on everything
Author's Statistic:
Threads: 37
Likes Given: 10
Likes Received: 35 in 31 posts
Home Port: Annapolis, MD
Vessel Info: Currently looking
Author's Statistic
Threads: 37
Likes Given: 10
What kind of hose are you using on deck? The small diameter spiraled hoses I think work the best to keep pressure up.
