Author's Statistic:
Threads: 9
Likes Given: 5
Likes Received: 15 in 10 posts
Home Port: NY, Long Island, South shore
Vessel Info: 1998 4000 Express, Cat 3208
Threads: 9
Likes Given: 5
Dumping a bottle of Halon into the E.R. would shorten a trip pretty fast so I'm guessing it's just lights. I'd honestly have the whole thing looked at by a pro. I'm pretty handy but I don't trust myself to get it perfect and would never forgive myself if someone got hurt.
(09-28-2021, 05:41 PM)Misdirection Wrote: When you say activating after 3 to 4 hours of cruising, do you mean the lights at the dash only come on then? Not really sure what issue your having.
Found the engine room temp getting too high and setting off the fire supression sys. Tank is located too close to the turbo on the port side bulkhead. Added ventilaion to the engine room and relocated the tank to aft centerline. Problem solved.
The following 1 user Likes makowalski7587@icloud.com's post:1 user Likes makowalski7587@icloud.com's post Misdirection (01-27-2022)
