I have a 2006 Coronet. Both Tachometers show RPMs fine, both backlights work but neither of them shows the hours. If it were just one I would think it was a loose/corroded connection but that seems unlikely since its both. Every once in a while underway I can see some garbled text where the hours should be. It sort of goes in an out.
Is it better to just replace them? And if I replace them can I program them to start at the current hour read?
Rebuilding could be another option. Have the guys at Lauderdale Speedo take a look at them. At a minimum, they can tell you whether the issue is internal.
(06-08-2022, 07:50 AM)MC1600 Wrote: Rebuilding could be another option. Have the guys at Lauderdale Speedo take a look at them. At a minimum, they can tell you whether the issue is internal.
I reached out to those guys -- EXTREMELY HELPFUL and VERY RESPONSIVE! They basically said they could rebuild or replace. Thankfully they said the tachs are still recording the hours even if not being displayed.
08-29-2022, 06:16 AM (This post was last modified: 08-29-2022, 06:18 AM by Newbie7749.)
My tachs were very easy to access - when you pull the console forward, my guages just twist about 45 degrees and then pull right out (pull backword into the console.
