Author's Statistic:
Threads: 2
Likes Given: 1
Likes Received: 0 in 0 posts
Home Port: Bay river NC
Vessel Info: 2005 Limited 3100
Cummins
Author's Statistic
Threads: 2
Likes Given: 1
Cummins
After moving on plane there is a beeping sound all gages are normal
After decreasing speed sound will slow down and stop when Idling
Author's Statistic:
Threads: 29
Likes Given: 5
Likes Received: 26 in 22 posts
Home Port: Annapolis, MD
Vessel Info: Currently looking
Author's Statistic
Threads: 29
Likes Given: 5
Is it the same sound you get when you first start up? If so, I’d start with examining oil pressure. Don’t trust the gauges at the helm and toss a mechanical gauge on the motor to rule that out.
Author's Statistic:
Threads: 2
Likes Given: 1
Cummins
Author's Statistic
Threads: 2
Likes Given: 1
Cummins
Thanks for info. When I tip console back two alarms one on starboard one on port right side alarms when keys are on port side is the alarms while underway
Author's Statistic:
Threads: 3
Likes Given: 144
Likes Received: 43 in 40 posts
Home Port: Ashtabula, OH
Author's Statistic
Threads: 3
Likes Given: 144
Not knowing what motors you have, but if you have gas motors, the engine alarm goes off for one of three reasons.
Oil pressure, engine temp, or transmission temp.
First things first. Check your oil, and transmission fluid levels. If their fresh water cooled, check antifreeze levels.
Author's Statistic:
Threads: 2
Likes Given: 1
Cummins
Author's Statistic
Threads: 2
Likes Given: 1
Cummins
6bta5.19 Cummins
I’ll check what you said thank you
Author's Statistic:
Threads: 3
Likes Given: 144
Author's Statistic
Threads: 3
Likes Given: 144
Ok, I'm not sure anything I provided applies to diesel's, but that would still be a good place to start.
Author's Statistic:
Threads: 2
Likes Given: 1
Cummins
Author's Statistic
Threads: 2
Likes Given: 1
Cummins
Thanks to all it was a loose ground bus bar
Regards
