bearing & rollers for companion way sliding door 1997 33 Open
Hi
Does anyone know where to get the rollers for the old style companion way sliding doors. They don't use that system anymore, Tiara doesn't have any parts left  and they don't know of a supplier. The new system is the truck, train and track system. Thinking about trying to retro fit that new system if I can somehow. It would require cutting the top and bottom of the door. Not sure if it will even work. I'm a little screwed right now.
Kurt
I thought you had solved this, Kurt...
Pomanette (Stephanie Allen) sent me a file for rollers and thinks one set or the other is correct.  I haven't taken it apart yet to look.  Since I believe you took yours apart, see if this helps...
.pdf   ROLLER KIT COMPARISON.pdf (Size: 171.83 KB / Downloads: 52)
(04-19-2015, 10:49 AM)Harwood Wrote: I thought you had solved this, Kurt...
Harwood
Thanks for the link. I need the whole cage assembly also, or the ones that fit my door with those bearings in it. Maybe I will give them a call tomorrow.
  bathroom door handle fuzzy 2 634 07-18-2026, 05:43 PM
Last Post: fuzzy
