04-09-2017, 06:11 PM
(04-09-2017, 04:53 PM)CaptBrett Wrote:(04-09-2017, 07:22 AM)ReelMagic Wrote: Before I change the cal rod I would ensure you have 110v at the hot water heater itself.....Need to remove the cover where the electric wires go into. Another test is to reset the overtemp sensor located under the same cover... I've attached the manual for the heater.. Look at pages 4 & 5, especially page 4 step 8 on reseting the overtemp switch.
Following replacement of my hot water heater I tried to remove the cal-rod from the tank but was not successful. Believe the Aluminum tank corroded the threads... M2C
Thank you again.... so i have been told this water heater has a heating element ? Is that correct ?
I have water running thru it, flipped switch a number of times, to see if my volt gage would move, but nothing, so i guess its not getting power ? Thoughts ? This is a big help I appreciate your help
Here is another? For you... i am searching for a carpet for my helm area.... only have found one online vendor where you can make you own template ship to them they will make carpet for you.
Do you have a carpet? Thanks again
