Zinc bolts in transom
2005 Sovran 36
Today the diver told me that one of the bolts holding the zinc on the starboard transom was broke off at the hull.  His advice was to have the boat hauled to examine and repair rather than attempt an in water repair.  My question is has anyone had this happen before, and if so what type of process is it to fix.  My second thought is that it may be better to just let it lay, and use the remaining bolt with a modified zinc, rather than risk some bigger issue trying to replace the bolt.  Any thoughts?
Attached Files Thumbnail(s)
2005 36 Sovran
Cummings 6C-AT 480
Get it fixed. Why would you knowing leave your boat in the water when something is wrong. Maybe the bolt 'hole' is now allowing water to leak into the boat or worse into the lamination and may cause further damage. Easy fix for what I can see, haven't had to do it but can't be that difficult. Don't wait, haul, repair, while your out pressure wash bottom, change all zincs, bottom paint, wax etc. Get it done right.
  Transom Door/Gate Repair MC1600 4 4,540 08-25-2025, 10:53 PM
Last Post: Splendor
  [Tiara Open] Zinc Sizes - Tiara 2700 Open peakay 0 608 07-08-2025, 10:21 AM
Last Post: peakay
  1990 3100 open - can I add a transom door? 604.jim.smith@gmail.com 0 647 05-27-2025, 04:49 PM
  [Tiara Sovran] 2004 36' Bracket for Transom trunk broke mskilliter 0 932 04-04-2023, 02:05 PM
Last Post: mskilliter
  3100 Open Transom Grab Handle Simvt1 0 1,231 08-06-2022, 04:09 PM
Last Post: Simvt1
