Holding tank leaking
I have a 2000 Express. The holding tank is leaking. Any suggestions on how I go about replacing.
Check with a good metal marine fabricator. Depending on where the leak is located and what caused it it may be repairable. On my last boat I had a galvanic issue that weakened the welds (stainless) so we decided to replace. Used a plasma cutter to get old tank out and then fabricated two smaller tanks that were able to be dropped in through the access. If you don't need a lot of water a single smaller tank may do. I also looked into installing a bladder but found the cost not that far off having a new tank fabricated.
Good luck
(07-16-2017, 04:24 PM)dbruce222@gmail.com Wrote: I have a 2000 Express. The holding tank is leaking. Any suggestions on how I go about replacing.
Are you asking about the the waste ( black water ) holding tank?    That's a s@#$%^ job.   Is it metal or plastic?
Yes it the black water tank. Vent clogged. When I pumped out top of tank collapsed and broke tank. The only way to get same size in is to remove fiberglass liner all around back cabin. If we cut out floor i have to put in a much smaller tank.
I have a email into Tiara to see if it is possible to remove liner or if there is another place I can put tank
Tank is aluminum
  1997 4000 Express - Holding Tank Replacement jennyJ 9 5,119 05-26-2026, 07:27 AM
Last Post: frank.koetter
  Water tank level sensors Final Pursuit 4 2,401 10-09-2025, 06:37 AM
  Holding tank collapsing fix giff1 5 3,155 10-18-2024, 06:00 AM
Last Post: egstasea
  2018 38LS Black water tank location Scottbee 1 1,813 03-11-2024, 10:27 PM
Last Post: Scottbee
Question [Tiara Open] How can I repair crack in bottom of holding tank without removing tank? TimmyTime 2 3,297 06-06-2022, 02:16 PM
Last Post: August Rush
