2003 3100 Open LE helm color
I'm in the process of installing 2 furuno 12" tzt2 unit at the helm, i have made a template which I'm going to have a machine shop burn out a trim panel so it looks similar to factory, and then I would like to paint/powered coat it to match the dark blue of the helm. Does anyone know what the color is ?  Or what a matching paint code would be ?
Probably what tiara calls flag blue. I bet if you emailed the company they could get you a color code for it.
Keep in mind that it has likely faded etc since 2003. You're probably best off cutting a small piece out (that will be covered by new plate) and having your paint shop color match it...
might be worth a quick call to Tiara. They used to use Awlgrip colors for arches, frames, etc. which closely matched gel colors. Flag Blue is a common Awlgrip color and is a good bet if your dash is dark blue. If it is a custom color Tiara will more than likely give you the Color code or part number if matched to an Awgrip custom color (awl mix). You can also get a color card from Awlgrip and see if it matches. A good powder coat shop may be able to match the color card as well.
  [Tiara Open] Extend Swim Platform 1988 36 Open tomconroy 4 4,751 02-07-2026, 12:15 PM
Last Post: jgaudet2
  Adding a generator to a 3500 open Simpleg1 0 1,486 08-31-2025, 01:43 PM
Last Post: Simpleg1
  Adding a Live / Bait Well to my 3200 Open ove.schuett@comcast.net 1 1,341 07-07-2025, 06:55 PM
Last Post: Woodworker2001
  [Tiara Open] Larger and Smart TV for 2006 3600 Open Trainman 1 1,980 06-18-2025, 03:20 AM
Last Post: Roweje
  [Tiara Open] '86 3600 Open Cockpit Deck Hooper 2 1,880 12-10-2024, 10:57 AM
Last Post: Hooper
2003 3100 Open LE helm color00
