oil change system
have a 2003 42 open tiara with oil change system, help, lol, how does this exactly work??? its do for a oil change from previous owner and dont want to screw it up, thank you..
I have a 2003 38 Open w/oil change system as well. Assume its the same. System has 5 red valves and a switch (2 position) that allows you to remove or fill the engines, transmissions, and generator. I only use the system to extract engine oil, transmission fluid and generator oil. Normally I run the engines and generator to warm the oil before doing an oil change. After running the engines and generator I start with one engine and do the following:
1) remove the dip stick to allow air to enter the oil pan. (replace following oil change and prior to starting)
2) open the appropriate valve on the oil changer
3) place a 5 gallon pail in the engine room and put the oil changer hose into it and start the systems placing the switch in the "remove" position.
4) once all oil is removed from an engine I shut the switch off and close the valve for that engine on the oil changer system
5) repeat steps 1-4 for second engine and generator. (BTW my boat has a second valve near the generator that goes to the oil changer system that needs to be opened as well)
6) Same procedure is used to remove transmission fluid for each engine..
Once all oil is removed I shut the oil changer off at the breaker panel and ensure all valves on the system are in the "OFF" position.I then refill each engine with 15W40 Rotella T(same for generator). I use Rotella T 30 wt for the transmissions...
Assume you are also changing engine oil filters as well. When changing the filters I preload each filter w/3 qt of Rotella to ensure the engine doesn't starve for oil when starting the first time... M2C
thank you for the quick response
(06-06-2019, 07:56 AM)ReelMagic Wrote: I have a 2003 38 Open w/oil change system as well. Assume its the same. System has 5 red valves and a switch (2 position) that allows you to remove or fill the engines, transmissions, and generator. I only use the system to extract engine oil, transmission fluid and generator oil. Normally I run the engines and generator to warm the oil before doing an oil change. After running the engines and generator I start with one engine and do the following:
Thanks from me as well.  We have a 2005 38' Open Tiara.  Looks the same as described.
Hi guys, i know this is an old post but i am getting ready to change the oil on my 2005 3800 and i too have not used a changer system like this before. What is the down the down side to using the changer to put the oil back in?
I'm not sure if there is a down side but prefer to fill each engine/generator so I know exactly what is going in... I also pre-load the engine oil filters w/3-3.5 qts of oil before installing them on each main engine. This to ensure oil is available when starting the engine the first time after changing the oil... M2C
Agree with ReelMagic. I take an empty 5gal bucket and mark the outside with tape where each gal is (doesn’t have to be exact). Empty the first engine, make a note of how much came out, empty the second engine, and figure the difference (they’re obviously pretty close to the same).
Then I fill both engines from the top with the amount I removed. I always have to add a little more after restarting because of the filters (CAT doesn’t want mine prefilled).
  [Tiara Open] Trim Tab Hydraulic System Bob's Boat 0 439 07-19-2026, 02:41 PM
Last Post: Bob's Boat
Information 2000 express 4000 fuel system questions... bman440440 2 1,338 07-23-2025, 08:19 PM
Last Post: bman440440
  water and waste tank monitor system duckbofetch 5 2,423 05-01-2025, 08:39 AM
  Power issue livewell and oil change pump smagistro 1 845 04-22-2025, 06:07 AM
  Cooling System Service for 2011 Sovran 45 Max5514 0 777 07-23-2024, 11:55 AM
Last Post: Max5514
