Tiara Coronet Repalcement LED navigation light suggestion
I have a '97 Tiara Coronet & my white navigation light has been giving me problems. I want to upgrade to an LED model, but can't find one that will fit this mount. I contacted Hella Marine but no luck.
Any suggestions?
[Image: 49889854256_8748edac2a_z.jpg]
[Image: 49889855061_994c751e1e_z.jpg]
What issues are you having with it? If the contacts are corroded causing flickering etc cleaning them with some emory cloth may help.
I ended up just replacing the bulbs and lenses in the similar Perko mast light on our 42. I believe I found the bulbs on superbrite led's website.
Max
The first thing I tried was cleaning the contacts, which weren't bad to begin with. I can get a bulb in there & it will work (it's just one side that's giving me a problem), but once I put it back together the slightest jolt will cause it to go out. It seems like a waste to try & put an LED in there if there's a problem with the electrical connection.
I was just thinking that perhaps I have the wrong bulb in it as there are a lot of similar sizes with these festoon bulbs.
Thanks for the help.
(05-17-2020, 12:21 AM)stugiv Wrote: The first thing I tried was cleaning the contacts, which weren't bad to begin with. I can get a bulb in there & it will work (it's just one side that's giving me a problem), but once I put it back together the slightest jolt will cause it to go out. It seems like a waste to try & put an LED in there if there's a problem with the electrical connection.
If it's a bulb with contacts on the bottom, try adding a drop of solder to the bulb base to enlarge the contacts.  Also make sure the contacts in the socket are clean and floating loose on the spring hidden below. A good dab of grease also helps keeping it from corroding.
Capt.  George
  Navigation Lights Jarrod 2 1,614 04-03-2026, 08:25 PM
  [Tiara Sovran] Red/Green Navigation Lights Premium Pleasure 1 792 04-30-2025, 06:43 AM
  [Tiara Sovran] Replace bulb in 2004 Sovran Bow Nav Light? Don P 0 968 07-12-2024, 03:11 PM
Last Post: Don P
  [Tiara Sovran] Front stateroom closet light not working. Is there a switch somewhere? Gbrooksct 4 3,698 07-08-2024, 08:49 AM
Last Post: Pop Alexandra
