Engine Block heaters
I am new to this forum and appreciate how useful it has been just following some of the threads.
This morning I noticed my engine room was warm which lead me to head down below.  The Port engine was warm (not hot) and so I assume the engine block was inadvertently activated.  Hence my question.  I never turned it on and I do not know where to locate the switch to do so.  For now I switched the breaker for both port and starboard off and that seemed to solve the issue.  Any idea where the switch’s are for the to turn on/off the engine block heaters?  Thanks
I have the same engines and almost the same boat. My 120V panel has breakers for the heaters.
Thanks. Yes that is what I turned off. Is that the only way you turn the heater blocks on and off is with the breaker panel?
Yes. They only work from the panel.
There should be a dedicated breaker for the block heater that controls only that circuit.
Thanks for all the replies. I appreciate it.
Last Post: hmtrerice
  3500 Exp. engine hatch not working. giff1 1 966 11-17-2025, 09:56 AM
  [Tiara Open] 2900 engine mounts North000 0 681 06-06-2025, 03:47 PM
Last Post: North000
  [Tiara Sovran] Sea Strainers on 2009 Volvo Diesel Engine Donaldjames 3 3,643 04-10-2025, 08:23 PM
Last Post: Donaldjames
