43 OPEN with 660 hp CAT's - best prop?
Anyone have any advice on the best prop to use for a 43 OPEN with CAT 3196's making 660 hp.  I have to replace my set and was wondering if there is any new technology versus the traditional 3 blade prop that I am using now.
Current prop on boat is Federal Equi-Poise Cup 27x36.  I hit 2330 rpm's WOT at around 33 knots.
I would say you are propped correctly.  2330 is what the 3196s should see at WOT.
2020 53 Fly
Gulf Coast Florida
The Acme 4 blade should give you a little stern lift and a little better speed across the rpm range. They are an expensive set of wheels but if cost is no object then take a look and more importantly, see if you can borrow a set to see how your boat performs. 2320-2350 is what you want to see at full engine load and gross vessel weight.
Thank you for the information. Did you switch from 3 blade to 4 blades and experience the increase in performance?
I did not change out the props on my 43 but another 43 open maintained by the same yard put them on and reported well over a 2 knot speed increase, smoother operation and better handling. If you are serious send me a PM and I’ll try to connect you with the owner who has first hand knowledge.
pm sent thanks
  [Tiara Open] Pre start for 2000 31 open b_glacken@yahoo.com 1 1,396 03-27-2026, 08:07 AM
  [Tiara Open] Kicker install on 1990 31 open remodel4@comcast.net 4 5,887 11-12-2025, 09:32 AM
Last Post: fkrabach
  [Tiara Open] Tiara open 3000 - 2007 maxcav 2 1,664 05-25-2025, 08:25 PM
Last Post: Roweje
  Trailering a 32 open douellette48 3 2,998 02-07-2025, 08:46 PM
Last Post: Hifirush
  [Tiara Open] Repower an '84 3100 open with V6 or V8 diesels SaKiawa 7 7,297 12-02-2024, 09:25 AM
Last Post: Hooper
