Threads: 3
My T&P relief valve is leaking and probably needs to be replaced. Does anyone know the temp and pressure threshold specs for the valve
Threads: 22
5
Home Port: Stuart, FL
Depends on your brand of water heater. Just Google "marine hot water tank parts" and go to the Defender site. They have a large selection with specs, depending on the brand. Typically 190-210 F and 75, 100, 150 PSI.
As a suggestion, NEVER flip the lever to flush the valve as some recommend. If you do, plan on replacing the valve, it will leak. Never had one that did not leak afterwards.
