2006 Tiara 30 Open ignition question
My 30 open has twin 330 Cummins QSB 5.9's
Is this normal?
I can start and stop each engine individually with it's appropriate engine key.
Once both engines are running together, they only shut off together when both keys are turned off.
Turning off one key does not kill that engine until both keys are turned off, then both engines shut down.
I can't turn off one engine by itself after both engines are running.
Does anyone else experience this on their Tiara?  Are my ignition switches wired wrong?
Thanks in advance
Sounds like a wiring error. Do you have an engine room fire extinguisher system? That should be wired to shut off both engines in the event of a fire so that your extinguishing agent is not inhaled and consumed by the diesels. Perhaps the error is in this circuit. Sounds like you need a GOOD tech that knows his stuff, not just a 12 volt man.  Capt. George
(01-27-2016, 09:22 AM)Uhehner Wrote: Sounds like a wiring error. Do you have an engine room fire extinguisher system? That should be wired to shut off both engines in the event of a fire so that your extinguishing agent is not inhaled and consumed by the diesels. Perhaps the error is in this circuit. Sounds like you need a GOOD tech that knows his stuff, not just a 12 volt man.  Capt. George
Thanks for the insight to the fire system.  I will report back next week when I get to work on this.
  Anyone using a cordless robot on a Tiara 3500? thomasbrown 0 50 11-03-2026, 05:08 PM
  Anyone using a cordless pool cleaner with a Tiara 3500? gracewilson 1 84 11-02-2026, 01:18 PM
  [Tiara Open] Pre start for 2000 31 open b_glacken@yahoo.com 1 1,396 03-27-2026, 08:07 AM
  [Tiara Open] Kicker install on 1990 31 open remodel4@comcast.net 4 5,887 11-12-2025, 09:32 AM
Last Post: fkrabach
  Just purchased a 2006 Tiara 3200 new Buffalo MI Mmiklosz 0 551 11-05-2025, 11:28 AM
Last Post: Mmiklosz
