Threads: 14
Home Port: Key West, FL
Vessel Info: 1996 3700 OPEN
CAT 3208 435 HP
I have 1997 3100 open that has developed spider cracks in the non skid on the lower deck right where you step down. There does not seem to be any flexing in the deck and nothing has been dropped on it. I asked Tiara about it and they said that it is not common. So am I the first and only one this is happening to? If not were you able to find a cause and correct it? How do I fix it or do I just have to live with it? I hope that it is purely cosmetic and not structural. Any thoughts?
Threads: 1
I have the same thing on my boat 1995 3100 open. Mine are just to the port of the step down
Threads: 14
2
Seems to be common theme. My 98 31 Open has a few in the same spot right where one steps down from the upper cockpit. The non skid "shapes" are actually wearing away a bit from the foot traffic. My cracks however are only a few inches, not all the way to the fish boxes. There are a couple along the aft fishbox across the hinge but they are really minor.
I'd hope it's cosmetic as well. I saw a story about gel-coat cracking because of compression caused by the straps on the travel lift when boats are hoisted. The article was focusing on the gunnels and topsides, but if the straps are compressing the whole boat, cockpit center-line would be a weak point between the gunnels. Just a thought?
