Auto Pilot Course Computer Location '01 3500 Open?
Any idea where Tiara located the AP Course Computer on this boat?  I don't readily see it behind the helm, below the companionway steps or at the front of the engine room (though given the heat I would not expect to find it there).   The control head is a Ray ST7001 which I believe requires a separate Course Computer located in a dry location, preferably toward the center line of the boat as low as possible.
Dave
Check under the settee next to the stereo amp. I am almost positive that is where mine is....
(11-29-2017, 12:32 PM)tyresmoker Wrote: Check under the settee next to the stereo amp. I am almost positive that is where mine is....
Thank you for the suggestion.  I don't find my CP in that location--just my stereo amp.  But that would seem to be a very good location for it to have been.
Dave
Can you track the seatalk cable out of the control head back to the course computer? the power wires from the helm pump or the signal wires from the heading sensor will also lead to the CC
mine was mounted to a bulkhead right behind the dash/instrument cluster. Same year but different model boat ('01 43 open). Good luck.
(11-29-2017, 10:43 PM)jclark003 Wrote: Can you track the seatalk cable out of the control head back to the course computer? the power wires from the helm pump or the signal wires from the heading sensor will also lead to the CC
Thanks.  I will try to trace the seatalk cable out of the AP control head next time I am at the boat.  The only two boxes mounted on the bulkhead behind my helm are the DSM250 for the fishfinder and the ST290 Data Processing Unit, so mine is not in the same location as yours either.
Dave
Dave
To close this out--found it very close to where tyresmoker suggested.  I had to take the back of the settee itself off which exposed a panel that they were hiding behind.  Below the AC panel but above the base of the settee where my stereo amp is.
  Refrigerator replacement for 1989 Tiara open/express Halekai 1 3,625 03-08-2026, 11:03 PM
Last Post: Longbeach3910
  2008 36 Open with Cummins Dosplays Afarneti 1 4,367 03-04-2026, 05:56 AM
Last Post: ken9090z
  2000 3500 Express Raymarine c120 Radar Replacement - Ohio River JMGCINCY2023 5 7,684 09-02-2025, 10:06 AM
Last Post: sluggo
  [Tiara Open] 1996 33 open gauges Mydiamond 1 4,659 08-18-2025, 10:57 AM
  [Tiara Open] Loose parallel wire behind ignition plate 1996 Tiara open Mydiamond 0 4,397 08-14-2025, 08:05 PM
Auto Pilot Course Computer Location '01 3500 Open?00
