Fresh Water Washdown
I had to pull my freshwater washdown to run some wire. The freshwater washdown broke getting it out. Amy idea where I can order a new one?
Hi,
Are you talking about the female 'push lock' hose adapter?
Ken
Yes but I need the entire module. I had to remove the whole piece to run some wire and whatever sealant used to install it was very strong I ended up breaking two corners off. There are four screws, one in each corner, and it is located just below the main A/C breakers in the cockpit on the starboard side.
On my boat it is a recessed 'box' - it has both the fresh water wash down and the raw water wash down.  Is it about 8" x 4" by about 2" deep?  I had mine 'repaired' at a local fiberglass shop - same thing happened to me when one of the fittings went bad, and I had to pull the whole box to get to the back of the fittings.
Ken
USA Flag
That is the box. Mine is banged up pretty bad. Looks like I might have to fabricate something. I found a round recessed fitting. I think a piece of starboard with the single round fitting in the center might do the trick if I cannot find anything else. Spent a good hour searching the web for something I can use.
If i remember, mine had the actual Tiara part number written in Magic Marker on the back side of it. I called Tiara and it was still available, but on the pricey side. Tiara CS can always look up parts if you give them the HIN. Hope the season warms up soon! We are out on the North Fork, Where do you keep your boat?
Ken
I am right across the pond from you in CT. I will try Tiara. I have contacted them before with success. Lets hope this is the last crappy weekend, it has to warm up eventually.
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,682 05-12-2026, 10:18 AM
  [Tiara Open] 2001 3800 Open Holding Tank cap that hold sensor and washdown twilson0929 0 839 05-12-2026, 10:18 AM
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,805 02-23-2026, 11:01 AM
  Water alarm in the diesel filters maxcav 0 519 02-15-2026, 05:34 AM
Last Post: maxcav
  Water if forward bilge after rain lenoah 0 630 11-21-2025, 05:53 PM
Last Post: lenoah
