Threads: 1
Home Port: Williamsburg, VA
Vessel Info: 40 Express
1998
Cummins 450 HP
I am assuming you have the cable master setup....we replaced our white 50A cable....I would suggest contacting Glendinning directly and they should be able to help you out. PS: we salvaged 25 feet of the old cable and simply had the shop add a female connector to the cord to carry as an extension.....Simple solution on the plexiglass would be to install marine fabric with 4 snaps secured to the metal door frame....easy on, easy off. good luck
Threads: 14
11
Home Port: Kings Park, NY
06-15-2021, 06:23 AM
(This post was last modified: 06-15-2021, 06:29 AM by ReelMagic.)
To make the cabin private at night I added a removable cover to the inside of the screen door itself. Made a piece of black Sunbrella canvas (any material you can't see through would work as well) cut to fit the inside of the vertical portion of the screen door (it's approx 18" wide x 24" high), w/2 pockets for wood dowels (1/4") to fit into (top & bottom).. Made 1/4" holes on the inside top & bottom on the vertical frames of the screen door that the wood dowels can go into holding the Sunbrella canvas making a shade... Been that way for 10+ years and works great, screen still functional letting air into the boat (top portion of screen) without making any permanent change or damage to the boat itself. May sound complicated and can take picture to make it easier to understand if needed. Let me know if you want a photo.. M2C.. BTW you can leave the cover on the door and it will still slide since it doesn't interfere at all.
Threads: 2
06-15-2021, 11:10 AM
(This post was last modified: 06-15-2021, 11:16 AM by jap201.)
Thanks both for the tip. No screen door tho. Thinking of using some velcro on the door frame, and some fabric with velcro just to block the view at night. boy, a screen door would be nice... wonder if its tucked into the door frame somewhere. going back tomorrow to work on the punchlist and will check it out.
thanks
Forgot to ask. Does anyone know where to get a copy of the cabin key? no one, and i mean no locksmith up in my area can find a blank to work. none of their computers even recognize the key. i'll be down in Ct. tomorrow and will try some locksmith's down there, but am not hopeful. its a simple key too (double sided tho), I don't understand why its so difficult for this key. they were able to dup my engine keys, but those are simple 1 sided keys.
thanks
Joe
Threads: 2
that looks pretty close, i'll check them out. thanks!
Threads: 0
Home Port: Long Island Sound
Vessel Info: 2007 32 Open
Cummins 355
The cabin keys are available directly from Tiara. Have you hull # when you call.
Threads: 8
10
Home Port: Port Canaveral, FL
3406E Cats
The southco keys usually have a number on them. You can order the correct key by giving them the number stamped into it.
Sans Peur 2003 Tiara 50 Open
Threads: 2
Thanks. Just heard back from Tiara, they have keys available so ordered 2 of them. Slowly working down the punchlist. Fixed a couple of things, and something else breaks. 21 year old boat, to be expected.
