Holding Tank leaks
Anyone have holding tank leaks on 40 mid cabin.  Previous owner did not change the vent filter and the top of tank con caved and is leaking.  During winter layup will need to tear up aft stateroom floor or put new tank in engine room. Any thoughts or suggestions would be helpful.  Jack.
I’m not gonna lie…seeing all these posts about tank issues in the 40 mid-cabins has me really freaked out. Is my ‘99 just a ticking time bomb?
(10-28-2021, 10:57 AM)MC1600 Wrote: I’m not gonna lie…seeing all these posts about tank issues in the 40 mid-cabins has me really freaked out. Is my ‘99 just a ticking time bomb?
NO. Just keep your air vent hoses clean and filter changed.
Conclusion on leak in holding tank. Throughly sealed existing tank and abandoned it.  Installed new tank under the aft stateroom berth.  To remove existing tank would have destroyed aft stateroom..  Able to fit 41 gallon tank.
i have a 42 open, where are the filters and hoses??? lol, help...
(02-21-2022, 07:31 PM)honest mark Wrote: i have a 42 open, where are the filters and hoses??? lol, help...
In the engine room you should have filter on the holding tank vent. Mine has hose type screw fittings on each end. Pretty easy to change filter.. Also check vent on outside of hull for all tanks..  spiders love vent hoses to nest as well as wasps.  Fuel, water and holding tank all have vents. Jack
Your vent filter should be mounted in the forward bilge (where the shower sump is) on the starboard side (likely screwed into the aft bulkhead in that compartment.  You will see a hose coming off the black water tank with a cylinder shaped vent filter leading to a vent in the hull side.
Max
  38' OPEN transom mounted bait tank Groper 3 4,125 03-26-2023, 01:42 PM
Last Post: seasalt32
  [Tiara Open] Holding Tank Sensor GeoDoc 5 5,235 05-04-2022, 10:43 AM
Last Post: GeoDoc
  1996 3100 open fuel tank size? Ruppertryan1@gmail.com 2 4,278 09-03-2021, 12:53 PM
Last Post: Chesfisherman1
  Fresh water tank Txcolor 5 4,827 08-19-2021, 07:31 AM
Last Post: mggilmorern@gmail.com
  Fuel tank replacement dbruce222@gmail.com 2 3,116 05-03-2021, 07:32 AM
Last Post: MC1600
