Tiara Sovran AC replacement under captains seat
Has anyone ever replaced or repaired a AC unit located in the helm under the captains seat. We have 2 units located under there and one of them is not working. Just wondering if anyone has any past experience with this . FYI they are Marine Air ( Dometic) units with 16,000 BTU . 2009 Tiara Sovran.
Yes. I removed the split gas system (evaporator under seat and compressor in engine room) and replaced it with a 16K self contained unit. This required running hard wall hose from pump up to helm unit as well as discharge to thru hull; pump relay connection; power; and rerouting thermostat wire. I ended up reusing the existing fan wiring and routing it as the pump relay so only had to purchase enough wire to reach breaker panel. Dometic makes a replacement self contained unit with a footprint very close to the old evaporator/fan assemble so it all fit very nicely. Was not a difficult job at all.
(05-31-2022, 08:42 PM)jclark003 Wrote: Yes. I removed the split gas system (evaporator under seat and compressor in engine room) and replaced it with a 16K self contained unit. This required running hard wall hose from pump up to helm unit as well as discharge to thru hull; pump relay connection; power; and rerouting thermostat wire. I ended up reusing the existing fan wiring and  routing it as the pump relay so only had to purchase enough wire to reach breaker panel. Dometic makes a replacement self contained unit with a footprint very close to the old evaporator/fan assemble so it all fit very nicely. Was not a difficult job at all.
Thank you for the reply, I have a heating and cooling boat specialists Arriving soon to help me diagnose the problem. Thank you very much for the prompt reply I really appreciate it. I will post an update as to what they find and how they fix it. Thanks again
(05-31-2022, 07:44 AM)Donaldjames Wrote: Has anyone ever replaced or repaired a AC unit located in the helm under the captains seat. We have 2 units located under there and one of them is not working. Just wondering if anyone has any past experience with this . FYI they are Marine Air ( Dometic) units with 16,000 BTU . 2009 Tiara Sovran.
Has anyone else replaced their air conditioning under the Captains seat at the helm? We are going to take on the task this weekend I just was wondering if anyone else had any experience with this.( By the way I had an excellent reply from Jay Clarke 003 just wondering if there was any additional input.)
hi there l just read your reply and l wonder if you might help me too.
owner of a Tiara 43 Sovran 2007, the A/C in the master cabin went off due to a problem to
the mother board which apparently has been discontinued something like 4 years ago by Air Sistem / Dometic.
Do you have any suggestion where to find a new (or a reliable used) one ?
many thanks
many thanks
Are you sure it’s the board? I had replaced my board as I thought that was the problem ( it was not ) and worked with a man in Florida named Rafael. Here is the number or the name of the company Yachtaid in Florida+1 (786) 621-3010
If it is indeed the board, he has a replacement for it. It has a slightly different wiring diagram, but he can walk you through it. It’s really simple. It did not solve my problem and I needed to replace my entire unit if you need information on that I have that as well.
  1997 4000 Express - Holding Tank Replacement jennyJ 9 5,119 05-26-2026, 07:27 AM
Last Post: frank.koetter
  [Tiara Sovran] A/C Compressor Replacement Cinquenodi 5 3,577 06-16-2022, 07:11 AM
Last Post: Misdirection
  AC pump replacement sluggo 15 18,837 09-12-2018, 01:24 PM
Last Post: sluggo
  Forward Shower Pump Replacement. Waterjammin 3 5,091 07-26-2018, 06:35 PM
  16,500 BTU AC under the Helm Seat 3500 Open Adventurous Soul 4 7,005 04-26-2017, 08:45 AM
Last Post: sbw1
