  • 1 Vote(s) - 2 Average
Tiara Sovran Horn compressor
Trying to find horn compressor on my 2006 Sovran 4300.  Stopped at wall behind vanity in aft stateroom.  Not able to find next access point.  Help?  Thank you in advanced.
Hi,
Ours is under the removable panels of the hard top. you might want to drop a quick note to CS at Tiara if you cant locate it.
Figures it out.  2006 Sovran 4600 horn compressor is mounted on port wall in engine compartment near holding tank.  It seems it is not receiving power to it, now comes my next search?
Have you checked the circuit breaker?
Yes,, circuit breaker tested and working fine.
Mines is mounted atop the water heater to the right of the starboard engine. There’s a reserve tank and a compressor along with the wiring. I’ve installed new diaphragms on the horns and purged the air line but it’s still kind of weak. Anyone have similar problems?
(05-10-2023, 06:23 AM)The Duke Wrote: Mines is mounted atop the water heater to the right of the starboard engine.  There’s a reserve tank and a compressor along with the wiring.  I’ve installed new diaphragms on the horns and purged the air line but it’s still kind of weak. Anyone have similar problems?
I replaced compressor also and that seemed to work on mine. it was 12 years old
  Horn stanfarbman 1 1,139 07-08-2025, 10:31 AM
Last Post: peakay
  C39 Horn Replacement - location of the Compressor? fishtiara17 3 1,354 02-26-2025, 10:14 PM
Last Post: Napercpl
  [Tiara Sovran] Air horn compressor Four Winds V 2 2,038 01-04-2024, 11:55 PM
Last Post: Four Winds V
  [Tiara Open] Trumpet horn replacement Capt. Tom 1 1,603 09-15-2023, 07:54 PM
Last Post: lakesidevu
  3500 express air horn giff1 2 2,667 05-10-2023, 06:12 AM
Last Post: The Duke
