Threads: 11
Home Port: Lake St Clair
Vessel Info: 1997 33 Open with 6b 5.9 Cummins diesels
Looking to replace the upper 2 bearing, 2 upper rollers and 2 lower rollers on companion way sliding door. Have a call into Tiara now, just waiting for reply. Just wondering if anyone has replaced these and has another source. Have it apart already, not that bad of a job.
Threads: 3
I was told to replace the track at the same time . Trucks and tracks from teak isle , not saying you can"t replace trucks only . There is wear on tracks that kills the life of the new rollers (trucks ). I did my whole system through tiara on their recommendation . You will have to cut track to length and drill holes . Its a great time to wax behind the tracks while they are off , you will be surprised how much crud builds around them !
