hydraulic lift table
I have a problem with my 2001 4000 Express table not raising from the floor.  Has anyone had this issue and if so what was the solution?
Is the motor working? Can you hear the hydraulic motor trying to turn the screw?
If yes, you can try to pull up on the table to take some pressure off the coupling and screw.
If you can get the table up, take some time to clean and repair the lift mechanism.
Good luck.
(09-04-2022, 11:32 AM)jes0065 Wrote: I have a problem with my 2001 4000 Express table not raising from the floor.  Has anyone had this issue and if so what was the solution?
Same answer here as from prior guy.  I have to have the Bride use the switch while I slide a finger under a corner of the tables where they come together.  I have lubed the heck out of them & still have to do it.  It's like the stbd table rubs against the port table, or they drop a bit too low to make it up under their own power.  Good luck.
  [Tiara Sovran] Main engine hatch gas shock lift assist bracket separation hmtrerice 0 386 08-21-2026, 02:33 PM
Last Post: hmtrerice
  [Tiara Open] Trim Tab Hydraulic System Bob's Boat 0 437 07-19-2026, 02:41 PM
Last Post: Bob's Boat
  2001 38’ Open interior table base removal twilson0929 3 899 07-07-2026, 08:13 AM
  4000 Express-Hatch & Table hydraulics; Anyone changed the hydraulic oil and filter? frank.koetter 5 4,652 05-06-2025, 09:57 AM
Last Post: Alan615
  [Tiara Open] 1996 Tiara 3300 open hatch lift part number?? Zemaestro 2 1,667 07-13-2024, 08:36 AM
Last Post: stephenalberg
