Tiara Open Servicing Seacock on a Tiara 3800 open
Can the Engine seacock in a Tiara 3800 open be serviced while the boat is in the water?
.pdf   Port Seacock.pdf (Size: 503.1 KB / Downloads: 6)
Guess it depends on that you mean by “serviced.” What needs to be done?
Opening and closing very difficult, damaged brass/bronze handle trying to close seacock
You could definitely replace the handle as that’s attached on the outside. Before doing anything dramatic, I’d shoot everything with some PB Blaster and let it soak in that. You could even remove the hose (with the valve closed), suck the water out, and shoot some down there.
If that doesn’t work, I think your only next step would be to deal with this during your next haulout. You certainly cannot open the valve with no hose while it’s in the water.
Thanks MC 1600
I was wondering if I could replace mine as well while in the water.
(02-17-2023, 09:05 PM)Joeboch348 Wrote: I was wondering if I could replace mine as well while in the water.
Only if you hate your boat and want to sink.
My boat is coming out tomorrow. Other than paint, the main reason is the port engine seacock is stuck open and I don't want to start beating on it in the water. Imagine breaking that off. A 4" hole in the bottom of the boat would not be stoppable. The least I would do is put it in the straps of the lift and then start working o it. If it is an easy fix you are usually only charged for the travel lift time and not blocking.
  Anyone using a cordless robot on a Tiara 3500? thomasbrown 0 41 11-03-2026, 05:08 PM
  Anyone using a cordless pool cleaner with a Tiara 3500? gracewilson 1 65 11-02-2026, 01:18 PM
  [Tiara Open] Pre start for 2000 31 open b_glacken@yahoo.com 1 1,390 03-27-2026, 08:07 AM
  [Tiara Open] Kicker install on 1990 31 open remodel4@comcast.net 4 5,874 11-12-2025, 09:32 AM
Last Post: fkrabach
  Just purchased a 2006 Tiara 3200 new Buffalo MI Mmiklosz 0 544 11-05-2025, 11:28 AM
Last Post: Mmiklosz
