Tiara Open 36 Open 2009. Shower drain
Dear Tiara Owners club,
Last week I was doing a check in the bildge and and I found lots of fresh water. I suspect that it is from the shower drain as I can hear it draining in an open space, but i'm not so sure. If anyone knows the answer I would really appreciate it.
Thank you
Sounds like (no pun intended) your shower waste line has become disconnected from the shower drain.
(12-15-2024, 05:42 PM)bruce@bigrivergroup.com Wrote: Sounds like (no pun intended) your shower waste line has become disconnected from the shower drain.
Thank you, I will check on it
Might be obvious, but do you realize that it drains to a sump box with a pump in it? If the pump is clogged (or has failed), it will just overflow into the bilge.
  2001 38’ Open interior table base removal twilson0929 3 909 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,531 05-22-2026, 06:41 PM
