Threads: 14
Home Port: Key West, FL
Vessel Info: 1996 3700 OPEN
CAT 3208 435 HP
So, I have a leak of Hydraulic fluid coming from the reservoir cap for steering. My mechanic says that he cannot put new threads in the aluminum and that the only fix is to replace the entire helm portion of the steering system (for $750 for parts alone). Have any of you had this problem and if so what did you do to repair it. Who was the manufacturer of this system for the 1997 3100 open? I am hoping that there is some kind of repair part or kit without replacing the whole thing. Any thoughts or ideas are greatly appreciated.
Dennis
Threads: 9
4
Home Port: Daytona Beach, FL
Vessel Info: 2000 Tiara 3500 Open
Cummins 6bta -370
I think pictures would help a lot.
Threads: 14
CAT 3208 435 HP
Unfortunately I am to far from the boat at this time. The leak is coming from the little plastic cap right behind the steering wheel, between the wheel and the helm wall. They say it is a fill and breather cap.
Threads: 14
11
Home Port: Kings Park, NY
If I remember correctly, I had a 1997 31 Open, the breather cap had an O-ring on it....... Not sure if yours has one or not but that may be the reason it appears to be leaking.... BTW my current Tiara which is a 38 Open has the same steering system and the breather cap also has an O-ring on it.... Both are Hynautics (Sea Star) steering systems...... M2C
Threads: 14
2
A little thread dope or compound or Teflon piping tape might seal the threads if there are any cuts too large? In combination with a a new o-ring it might not totally stop any leak, but minimize it a bunch. I'd try that before i spent any big dollars. Simplest is usually easiest fix - learned from experience.
Let us know if it works.
Threads: 14
11
Before I replace the entire unit I would re-thread the unit to the next size larger thread or install a "heli-coil" which would allow the original cap to be used. Would require cleaning the inside of the unit to ensure no metal chips get into the pump mechanism... Using the next size larger would also require a new screw cap that has matching threads.... Surprised that so much fluid is leaking..... Maybe Dakota773 fix may be the easiest/fastest.....
