Threads: 29
Windlass stopped working.
Any thoughts on how to test if it is solenoid or motor?
Can I put voltage across motor to see if it is working?
How do you test a solenoid?
Threads: 29
Thanks for the reply.
It is on a 2004 Tiara3200
Not only is it mounted in the anchor locker, it was installed before the hull and topsides were joined by Tiara.
I can see the installers in 2004 laughing at the guy who was going to have to change it out.
Same went for the Spotlight electronics. Just getting to the components was near impossible!
What year and model boat is this on?
You should be able to determine if it is the motor by using a meter on the leads coming from the reversing solenoid and having someone engage the switch. Obviously if there is power than it is the motor. In all likelihood it is the solenoid. On most models it is installed in the anchor locker which is not recommended by Maxwell due to the high amount of moisture present. The solenoid simply corrodes and fails. It is a pretty easy swap.
[/quote]
Threads: 15
Home Port: Port St. Lucie, FL
Vessel Info: 2004 Tiara 3200 Open, Volvo 310hp diesels
2016 Boston Whaler Sport 110, Mercury 30hp O/B
2019 Boston Whaler 170 Montauk, Mercury 115hp O/B
Meter tests the solenoid and u can test motor with a jump pack too. My dock neighbor's '07 30 Open has same issue. We tested it late last season - it was the solenoid. He ordered new one from defender.com. Swapping it out this weekend.
