Window washer
How do I get it to stop?
Tiara 3100
I suspect your window washer system is the same as I had on my 1997 31 and currently on my 2003 38 Open.. The washer system utilizes the fresh water pressure system as a source of water and there is a solenoid that allows pressure water to flow to the washer system when the switch is depressed on the dash. The  solenoid for both boats is mounted in the ER on the forward ER bulkhead on the starboard side... I'm assuming the switch is OK and the  solenoid is stuck partially open... A guess... M2C
bsause (02-22-2019)
If they don't see regular use they will stick open when used. Either use often or don't use at all.
  Repairing leaks to opening window on 3100 Open Coppifan 3 6,038 10-06-2018, 12:16 PM
Last Post: Tom Gaertner
  Paint to use on exterior of opening window Coppifan 1 3,264 08-24-2018, 07:27 AM
  1989 36 Window Actuators pshrubb 0 1,974 05-29-2018, 08:20 AM
Last Post: pshrubb
Window washer00
