Bait prep station for 3100 open
I considering buying a 99 3100 open that has the aft facing seat behind the helm and would much prefer the bait prep station instead. Are these available from tiara or is there anyone that would consider a swap? Is there aftermarket modules that would fit? The existing module is one piece, has anyone seen a custom conversion? Thanks for any help as this boat has everything else I want but I can't go without the prep station.
I would doubt Tiara would have these from 99' but it might be worth a try. You can also go to [Only registered and activated users can see links Click here to register] and see what they have in the off the shelf units that may fit. They will also make custom if you want to go that route. BUT, they are made out of starboard and not fiberglass but they are quality units.
Ok thanks I'll give them a call.
  38 open bathroom recessed light bulb twilson0929 3 429 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 347 08-18-2026, 02:11 PM
  2001 38’ Open interior table base removal twilson0929 3 699 07-07-2026, 08:13 AM
  1996 33Tiara open - shaft seal lubricant leaking Mydiamond 4 1,326 05-22-2026, 06:41 PM
  [Tiara Open] 2001 3800 Open Holding Tank cap that hold sensor and washdown twilson0929 0 725 05-12-2026, 10:18 AM
Bait prep station for 3100 open00
