Temporary Loss of Electric Power to Engine
1995 fuel injected 454 Crusaders. After filling up, started port engine, heard loud "popping sound, and no power trying to restart after at least 30 minutes of letting it alone. Limped back to dock on one engine, hooked up shore power, and after 20 minutes on charger boat started.
Any ideas on loud pop? Could have been a backfire but do fuel injected engines backfire? Could I have somehow fried the starting battery?
Thank you, and call me clueless.
Turns out the loud popping sound was the port battery exploding. Fortunately, the acid stayed within the battery box and not sprayed all over the bilge. In speaking with others about this issue, it sounds like its not terribly uncommon.
Another reason to switch to agm batteries. I will be making the switch myself after having extreme off gassing off bad sla batteries a couple times.
FYI, When you change from wet cell batteries to either AGM or GEL's you need to make sure your house/engine chargers are updated so that the correct charge rate and float voltages are correct. Wet cells are different from AGM's and GELS when it comes to charging/float values.. Discuss with manufacturer for your chargers and alternators...M2C
  1988 3300 Open - Voltage drop when lowering engine hatch or honking horn Pluto 3 1,439 03-24-2026, 09:46 AM
  1997 4000 express shore power issue Salty0ne 10 4,352 03-31-2025, 08:27 PM
  Electric Breaker panel Jbuchsdvm 5 5,040 10-21-2024, 10:08 AM
  2007 39000 Sovran Engine Hatch Won't Lift Kevin Spellman 3 3,581 08-04-2024, 03:16 PM
Last Post: rcwiegand
  Fridge and freezer isotherm combo only work with shore power or genset Toyoda 2 3,010 07-26-2023, 03:55 PM
Last Post: Sapphire
