Tach replacement 1995 33' Open
[attachment=551]I am looking to replace the tach's on my Tiara because they are jumping.
Connections are clean...
Anyone know the current replacement VDO line?
Thank you[attachment=550]
[attachment=552]the twist lock mounting is hard to find
Hello,
Before you buy new ones, see if you can locate the switch on back that is used to select the number of cylinders. Note where it is presently set. Take a small screwdriver and rotate the switch back and forth thru it's range several times and put it back where it was originally set.
See if that clears the problem. Often, those contacts corrode and can cause that problem.
Regards,
Paul
[-] The following 1 user Likes Capt. Paul's post:
Misdirection (09-22-2019)
Thanks.
Did the turning of the switches a few times as well as replaced belts.
Seams to have solved the issue.
(08-11-2019, 04:42 PM)Mydiamond Wrote: I am looking to replace the tach's on my Tiara because they are jumping.
Thank you
I think they are VDO Blue Line.
Capt.  George
  38 open bathroom recessed light bulb twilson0929 3 448 08-26-2026, 06:22 AM
  Replacement of Carbon Filter on vent line from Holding Tank. 38 Open ReelMagic 1 353 08-18-2026, 02:11 PM
  [Tiara Open] Fireboy FE-241 replacement roboh20 0 340 07-25-2026, 09:15 AM
Last Post: roboh20
  2001 38’ Open interior table base removal twilson0929 3 714 07-07-2026, 08:13 AM
  Freezer Replacement for 40' Tiara Reprise1 4 1,646 06-09-2026, 02:28 PM
Last Post: fuzzy
Tach replacement 1995 33' Open00
