TV 36' Open
Looking to replace TV in forward bunk with a smart tv.
I'm told the smallest smart is 24", looking for some idea's how to up grade Thanks
The Amazon FireStick will turn any TV with an HDMI outlet into a smart TV. That’s what we use on our boat and it works perfectly.
Thanks did you remove the original and install a larger tv
I removed what had to be original. Big old box TV with like a 12” screen. In the 4000, it sits in a cut out corner. I wanted to keep the new one in the same area, so mounted it diagonally in the opening. I think it’s a 22” television. Hangs off each end by like 1/2”.
I replaced with a 27" LG (27LQ625S-PU) and fashioned some wood blocks to the tv mount on the door so the tv flush mounts on the surface of the door. Remove the door for an easier installation.
Added an outlet inside the cabinet coming off the bunk outlet.
It's a perfect fit for the door and is a good size for the bunk.
  [Tiara Open] Pre start for 2000 31 open b_glacken@yahoo.com 1 1,397 03-27-2026, 08:07 AM
  [Tiara Open] Kicker install on 1990 31 open remodel4@comcast.net 4 5,887 11-12-2025, 09:32 AM
Last Post: fkrabach
  [Tiara Open] Tiara open 3000 - 2007 maxcav 2 1,668 05-25-2025, 08:25 PM
Last Post: Roweje
  Trailering a 32 open douellette48 3 3,003 02-07-2025, 08:46 PM
Last Post: Hifirush
  [Tiara Open] Repower an '84 3100 open with V6 or V8 diesels SaKiawa 7 7,301 12-02-2024, 09:25 AM
Last Post: Hooper
