Trailering a 32 open
Hello,
I'm looking to purchase a 2006 32 open and was wondering if anyone on here has one that they trailer.
Just wondering what trailer you have and the rig you use to pull it.
thanks
Unless you have a CDL and a huge rig, it's not happening. Well over 20klbs behind the truck, 13' wide, and likely too tall for most roads and bridges.
(12-20-2024, 12:44 PM)douellette48 Wrote: Hello,
thanks
Tiara 31 Coronet
Loadmaster trailer, they work with Tiara to ensure bunks are placed appropriately. ($12k)
Remove the Radar
Ford F450
I pulled it from Connecticut to Wisconsin. Just need to look at each State’s requirements for hauling oversized load.
As an old retired trucker, if you decide to trailer this size of boat, the above post is pretty spot on. Check with whatever state you will be driving in, you don't want to get stopped and not have the proper permits, and also get a truckers atlas. Go to a truck stop, check to see if they have a Rand McNally, for truckers. It will give you every low clearance, load limit bridge and other things you will want to know. I know it sounds like a lot of research, but it's easy. As for a truck, minimum of 1 ton dually or bigger, like the F450 mentioned above. You want to be able to get it going safely, but more importantly, you want to stop it even more safely, big boats need big trucks. Hope this all makes sense, good luck.
  [Tiara Open] Pre start for 2000 31 open b_glacken@yahoo.com 1 1,397 03-27-2026, 08:07 AM
  [Tiara Open] Kicker install on 1990 31 open remodel4@comcast.net 4 5,887 11-12-2025, 09:32 AM
Last Post: fkrabach
  [Tiara Open] Tiara open 3000 - 2007 maxcav 2 1,668 05-25-2025, 08:25 PM
Last Post: Roweje
  [Tiara Open] Repower an '84 3100 open with V6 or V8 diesels SaKiawa 7 7,303 12-02-2024, 09:25 AM
Last Post: Hooper
  Looking for a 2006 or newer 32 Open Matta0413 3 2,837 02-04-2024, 10:58 AM
Last Post: Matta0413
