Tiara Open C-Charles Charger Series 5000 failed
I have a 2003 38 Open with a pair of Cummin's 6CTA Diamond Diesels with 6 series 31 GEL Batteries (3 house & 3 Engine). The original,charger was a C- Charles series 5000 charger (40 amp) and it recently failed... Need a replacement and understand C-Charles chargers are no loner in production although I found one one-line (new)... Didn't believe it was a good idea to purchase as there was no warrantee with the unit (sold new but as is).. I'm looking for a replacement that supports charging GEL batteries. Know I've seen posts in the past and am looking for recommendations....Talked to a marine electrician and he recommended a Victron Centaur Charger as its almost an exact replacement... Any thoughts/recommendations?
Can’t go wrong with either Victron or Mastervolt.
thx for the recommendation
Centaur is a good choice for replacement if you're sure you're sticking with Gel/not going lithium. Note the 40/50/60 amp versions are all the same size, and the 60A is only slightly more expensive--would just need to check wire gauge and breakers. If you never require a quick recharge, then 40A would be fine. If you have a local installer that sells Victron I would encourage you to buy it directly from him.
  Tiara Express Battery Charger Replacement Svdb12@chartermi.net 0 716 09-07-2025, 11:19 AM
  original tiara battery charger drifter 1 825 07-09-2025, 10:22 AM
  Battery Charger issue 04' 32 open Coastie57 2 1,307 04-24-2024, 08:41 AM
Last Post: Matta0413
  Tiara 4300 Open Series Model S2 chadpugh 0 1,511 06-17-2021, 03:45 PM
Last Post: chadpugh
Question [Tiara Convertible] Engine Battery Charger AC Power Issue ShooktheHook 4 4,099 01-25-2021, 10:52 AM
Last Post: ShooktheHook
