05-27-2018, 12:29 PM
I recently discovered a leak below my galley faucet. I unscrewed the hose from the faucet & replaced the washer. It was a nightmare to reassemble because there is no excess hose & it didn't want to screw back on. I finally got it but it's still leaking, though much less. Barely noticeable.
My question is does anyone know the brand of the fittings used in the fresh water systems at this time? I'm considering replacing the complete fitting as well as adding a short extension to make it easier to reconnect. The hose appears to be Pex or comparable.
Thanks.
Thanks.
