Threads: 15
Home Port: Port St. Lucie, FL
Vessel Info: 2004 Tiara 3200 Open, Volvo 310hp diesels
2016 Boston Whaler Sport 110, Mercury 30hp O/B
2019 Boston Whaler 170 Montauk, Mercury 115hp O/B
Anyone replace their TV? What's a good one?
Threads: 8
Home Port: Catawba Island, Ohio
Vessel Info: 36 Sovran
2006
Cummins QSC 490h
I replaced mine on my 2006 36 Sovran with a Jensen. The ones on the boat were 12 volt so I could not use a standard one form Best Buy. I got it through Hodges marine. It fits where the old ones were. Here is the link.
http://www.hodgesmarine.com/Jensen-Je151...512led.htm
John
36 Sovran, Cummins QSC
Threads: 39
I went through the same thing with my 2006 Sovran, but I also learned a little about TV's. It seems many of today's TV's run on 12 VDC and you can get them at Best Buy. all you do is look at the specs. If they are 12vdc, just cut the cord to the power supply and wire into where the old one was!! Biggest problem is, in or around 2006 the TV's for over the air signal switched to Hi Def. So you either need a new TV that gets hi def, plus an antennae that receives hi-def, or you can use the old ones with a converter.
