docking lights
how do you replace the bulbs in the docking light housing? The boat is a 1986 36' open.
I have never replaced them, so you are going to have to take a good look at them. Most docking lights allow for bulb replacement from the inside. There are a few where you have to remove the outer lens in order to change the bulb. Take a look at the inside first to determine if they can be dissasembled from the inside. They may clip, twist or unscrew. Different manufacturers used different methods to access the bulb. When you install the bulbs, make sure to keep the bulb lenses clean and would use a dielectric grease in the socket to keep the corrosion down. If the housing is gasketed, you may want to replace them. Old gaskets and O-rings dry out after several years. Good Luck!
  Tiara 3600 Courtesy Lights No Longer Available Roweje 0 1,097 11-10-2024, 09:17 PM
Last Post: Roweje
  [Tiara Open] Switch for Lights in steps on 2007 3600 Ope Roweje 0 989 06-15-2024, 07:50 PM
Last Post: Roweje
  [Tiara Open] 3100 Dash lights tatum051 3 5,817 07-20-2023, 05:47 AM
Last Post: MuskyHuntr
  [Tiara Open] Red led control panel lights out lakesidevu 0 1,433 06-22-2021, 01:05 PM
Last Post: lakesidevu
  [Tiara Open] No Indicator Lights on AC Section of Breaker Panel It's A Need 3 3,704 12-26-2020, 10:11 AM
Last Post: Jimmy
