Question for Chris
Hi Chris... Do you know what size props were originally spec'd for the 2002 38 Open with 450 Cummins? Previous owner dinged one prop and I am getting about 100 turns less than I should at WOT. Boat getting hauled soon for bottom job, and want to get the props tuned up then.
Thank, Mark
Mark,
The original props were Federal 24x28 (3-blade)- HX300 #7 Cup Nibral. If you added a tower or you tow a larger tender, you may want to consider going to a 4-bladed prop otherwise the 3 blades are most efficient.
The 450 Cummins were rated at 2600 WOT. Full load you should be able to reach 2650 and light load 2700 (clean fuel, clean bottom, engines running properly with good injectors and Turbos).
Send me an e-mail and I can send you a performance sheet for a 38 with the 450 Cummins showing speeds at all RPMs and fuel burn.
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 659 08-17-2026, 05:31 PM
Last Post: Bford100
  3800 Open Water Tank Question Hifirush 6 2,518 09-06-2024, 08:17 PM
Last Post: Hifirush
  2007 Tiara Sovran 4300 bow hatch seal replacement question. skibumajg 1 1,876 07-15-2023, 07:12 PM
Last Post: mc307tank
  Dripless packing question ReelEnjoyment 3 3,099 10-08-2021, 11:47 AM
Last Post: ReelEnjoyment
  Help Please! 1994 Tiara 31 Open Alternator/Regulator Question mholts13@yahoo.com 2 2,975 10-15-2020, 12:11 PM
Last Post: mholts13@yahoo.com
